I picked up two of the below back in October 2015.
Inno3D GeForce GTX 980Ti Hybrid Black Edition 6144MB GDDR5 PCI-Express Graphics Card (C98TP-1SDN-N5HNX) GX-057-IN
I've been happily using them all this time yet tonight I heard a pop and then a slight hissing noise. I of course turned my PC off instantly and stuck my head inside to find the cause of the weird noise.
I found that the GPU in the first PCI slot has died a death. It seems as if the processor / main chip (whats cooled by the cooler) has expanded and pushed the cooler away as all 4 screw mounts have the plastic casing chipped and is coming way from said screws.
Also looking close at the pipes right near the main cooler it looks cracked and on dusty as if there has been a slight leak.
thanks!
