Yep, the guys at Kolink worked hard to pull in some good quality manufacturing and even have high power offerings now. Seen a good review or two.its literally for the misses to do her Teacher work & marking remotely. So Even the Quad-core will be at like 5% usage lol.
(also kolink is used by OC in their own builds so they must trust them enough for that)
adds en extra £80 thoughI wouldn't touch a Kolink psu with a bargepole even for a budget pc. Someone on here took the cover off a KL 400w and the components inside were the cheapest of the cheap. The psu you have picked is even lower in the lineup than the KL series so god knows what junk is inside that. If you click on the second picture on it's product page and enlarge it you will see that that so called 400w psu only has 276w on the 12v rail and they recommend 24/7 power not to exceed 300w. That says everything you need to know about it's quality.
I would have thought a Ryzen 2200G/2400G would be better for your usage than Intel.
What about a cheap Windows 10 key online and then go for your AMD build in post #3? Quite a few on here have gone for these cheap keys and have had no problems with them. You could even drop the BeQuiet psu for a Silverstone Strider SST-ST30SF which is a SFX psu (comes with a adaptor to fit normal cases) and saves £7 off that build. It's a decent psu and still has a lot more power than that pc will ever need. Review here.
not a bad idea any leads to follow?Why not buy a refurbished corporate desktop?
My basket at Overclockers UK:
- 1 x Primo Nano Celeron - Intel NUC NUC6CAYH Celeron J3455 Quad Core = £406.99
- Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
- Security Software:Bullguard Anti-Virus 2017 - 1 PC 1 Year **Offer Price**
- Solid State Drive:Kingston A400 240GB SATA 6Gb/s 2.5" Solid State Hard Drive - (SA400S37/240G)
- Memory:Kingston HyperX Impact Black Series 8GB 1600MHz DDR3L CL9 SODIMM Kit of 2 1.35V (HX316LS9IBK2/8)
the other thought i had was give my GF my PC & build a new one for myself. shes happy with that.true, but if your doing Word/Excel , should maintain a solid 60 fps at 4k and match an i core![]()
got a 1800X 16GB ram, just the footprint is massive
got it to this now
- 1 x Team Group Vulcan T-Force 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD48G2400= £68.99
- 1 x TeamGroup 120GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive= £22.99
- 1 x Cougar MG110-W Micro-ATX Case - Black Window= £30.95
- 1 x Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)= £99.95
- 1 x Intel Core i3-8100 3.6GHz (Coffee Lake) Socket LGA1151 Processor - Retail= £98.99
- 1 x Asus H110M-K Intel H110 (Socket 1151) DDR4 Micro ATX Motherboard= £47.99
- 1 x Kolink Core Series 400W 80 Plus Certified Power Supply= £25.99
