- 30 Aug 2018
Hi all.
I'm building in a pc-o7s and airflow is non existent so I'm trying my first loop. I am having to carefully consider each part due to available size and also aesthetic reasons.
So far I've got the following:
Probably https://www.screwfix.com/p/wednesbury-chrome-pipe-15mm-x-2m/54679
I will be getting chrome fittings and I don't have a brand preference.
What I would like to know is, what sort of fittings should I be getting?
I assume that I need to get 15mm fittings for hardline tubing to match the dimensions of the pipe I've selected, but how do the fittings then connect to the various blocks / rad / res?
Is there a standard size screw fit for all those parts that every fitting has?
Thanks!
- Bitspower MonoBlock ASR370TC RGB-Nickel Designed For ASROCK Z370 Taichi
- Phanteks Glacier GTX 1080 Ti Aorus GPU full waterblock
- Phanteks R160 or R220 RGB reservoir
- DDC 3.25 PWM
- XSPC TX360 Ultrathin radiator
Thanks!
