Hi everyone,
I would much appreciate any help/suggestions regarding this issue I have. I have recently bought a Corsair Carbide Air 540 (https://www.corsair.com/uk/en/Categ...40-High-Airflow-ATX-Cube-Case/p/CC-9011030-WW) to build up a PC.
However I had not noticed that the max GPU length you can fit in that case is 320 mm (this is keeping the two frontal fans of the case (which are these https://www.corsair.com/uk/en/Categ...dition-High-Airflow-140mm-Fan/p/CO-9050009-WW). Now the GPU I would like to install in this PC is 327 mm in length, which is a bit too much. One solutions I thought was substitute one of these frontal fan for a thinner fan whilst keeping most of the air flow volume. I had a browse in Overclockers and found this model (https://www.overclockers.co.uk/cryo...ick-pwm-700-1300-rpm-fan-140mm-hs-00d-cy.html) which is also 140mm but it is 13 mm in thickness instead of the 25 mm of the Corsair model.
My question is, do you think this is a valid option? Also, the mounting of these fans on the case is done through some predrilled screw holes in the metal frame. Would the Cryorig fan fit in the square position for the screws of the Corsair fan? if not, is there any adapter that could be used?
Many thanks in advance and all the best!
Alex
Alex
Yes, that also sounds as valid option, I did not think of mix match the fan size...
