Want to build a new PC for my use cases
Mix of Gaming,Programming,Multitasking & others.
(Thinking of 2920x 2950X & 16GB of ram at least)
Budget £3000 but the lower the better.
would love to see your thoughts
Miles better then that CLC . Run pump 100%
My basket at Overclockers UK:
Total: £159.89 (includes shipping: £9.90)
https://www.overclockers.co.uk/be-quiet-tr4-cooler-bracket-hs-01b-bq.html
Zenith should be fine with 16 core
CAM is aweful, just use boards fan controller
End up with something like this
Having such a small NVMe drive isn't worth it, same price rather get 500gb SSD .
Though if your doing heavy data processing and crunching then is a damn fast drive
THE CLC still not tottally sure at but the enemerax has a bigger cold plate and high heat dissipation.
nvme drive will only be used for the OS nothing else so seems silly going for 500GB
No wonder why that they have used a full sized plate, makes up for poor flow and head pressure and cheap aluminium rad and copper plate design hehe
Has to use higher rates fans to achieve its heat dissipation. A 30mm thick 120 has the theoretical heat dissipation of 400w if you used a 3000rpm+ industrial 30mm thick fan etc .
And hats off, they do seem like damn good fans, just a shame the rest of the unit isn't a nice.
Just grab a smaller cheaper nvme , or install your applications at least on the NVMe . Expensive drive to be sat unused, you'll find drive reaches its rated speed once it's about a 1/5 populated .
And I come from a very Pro Samsung family and get nvme drives for free and find them hard to quote for people's useage
was looking through AMD TR2 approved AIOs Bequiet isnt listed for 250W+
this is though, whats your thoughts?
https://www.overclockers.co.uk/ther...ition-water-cooling-unit-360mm-hs-04b-tt.html
swappedIt's 400w , swap for silent wing 3 and it's about 650w.
Units like Alphacool/ Bequiet & ekwb AIO run tubing sizes that are 10/8 mm inner diameter , above units are about 5mm ID .
You'll have to look at pump flow and pressure rates . Normally about double
i swapped the cooler to the bequiet toogot have everything match
also
https://seasonic.com/prime-1300-w-platinum
<20dba!
tbh kinda tempted to get the 7900x instead though.
