- 27 Jul 2018
Hi I just brought the above cooler, and not sure if I should have the fans;
A: blowing air out of the case.
OR
B: Blowing air into the case onto the CPU.
Can anyone help please. Thank you,
Generally blowing through the radiator out of the case is preferable, but it doesn't have to be like that. My case has the twin Rad on the front blowing IN though the rad. You will get better performance with the fan blowing through the rad instead of sucking through though. What case do you have?
OR
Which CPU are you using? Some AMD CPU’s report a higher temperature (delta 20 degrees), suggest you download HWInfo64 if that is the case and see what temperatures that is reporting.
Can you confirm the model of the cooler as I don’t recognise the CPU header?
Finally stupid question but did you remove any protective covering on the CPU block? Also which header on the Motherboard is the fan header plugged into? Always use CPU_FAN as this is what most motherboards regulate to control fan speeds on AIO coolers.
The Skylake X chips do run hot I’m afraid and the cooler has the slightly noisier SP120 fans but glad you found the solution. Sometimes the thermal paste can get a bit dried out but suggest for longevity to get a cleaning cloth out and apply some Thermal Grizzly Kryonaut paste, also with Skylake X make sure you apply the thermal paste properly as it’s a big processor die. Have a look out for Gamers Nexus videos on YouTube as they give good instructions on the process.
What you are experiencing is common. CLCs like you have need lots of airflow through their cheap radiators to cool, and high airflow means more noise. A good air cooler would have cost less money, had as good or better cooling and been much quieter as well. But you have what you have.
A big part of the problem may be your case fans. The stock 200mm front intake only makes 0.996mm H2O static pressure at full speed, which is about 2/3rds what I consider acceptable for case fans to be able to move needed airflow through grill and filter. This means your radiator fans have to work harder and are also probably pulling heated air coming off of GPU up and out through radiator.
Could you remove side cover and run system so we can see if temps are lower with radiator fans spinning slower?
If this helps, I suggest the below solution:
Remove all PCIe back slot covers. This greatly improves rear vent area for better front to back airflow around GPU whiich means lower temps. Get 2x PH-F140MP and install as front intake fans to flow cool air to GPU and up to radiator and 2x PH-F120MP for bottom 120mm intake fans to flow cool air to GPU. PH-F140MP and PH-F120MP are some of the best fans made and OcUK has both on special in 2-packs. PH-F140MP are £16.26 for 2-pack (£8.13 each) and PH-F120MP are £14.99 for 2-pack (7.50 each).
https://www.overclockers.co.uk/two-...140mm-fan-radiator-performance-bu-003-pt.html
https://www.overclockers.co.uk/two-...120mm-fan-radiator-performance-bu-002-pt.html
If you want things even quieter and the stock radiator fans cool at 1/2-2/3rd speed, changing radiator fans to PH-F120MP will lower noise even more. But this will only work if stock rad fans can keep CPU cool at 2/3 -3/4 speed.
Even if you were to change back to air cooling you would need this basic case airflow setup.![]()
LOLThat is incorrect they are loud even at low speeds. I am getting 25-29c now at 55% speed, but they are just ... loud
The stock case fans are very quite
Cooling vs noise is always a trade-off, i.e. each user must decide for him/her-self how much noise is acceptable to achieve efficient cooling. Having the right fans for the job is essential. If you are not satisfied with the noise of your radiator fans, then change them to something better...fans that will keep your CPU cool with a minimum of noise. At the moment, I think the Noctua NF A12x25 PWM is the best choice. They achieve excellent cooling, while keeping quiet doing so. Max speed is 2000rpm, with included Low Noise adapter mounted the rpm is capped at 1700 and even less noisy. They are a new generation of fans, not pretty but who cares as long as they deliver ? If I were you, I'd get 2 of those and get rid of the original rad fans or use those somewhere else in the case.That is incorrect they are loud even at low speeds. I am getting 25-29c now at 55% speed, but they are just ... loud
While I agree there is a correlation between cooling ability and noise, that is only one part of it.Cooling vs noise is always a trade-off, i.e. each user must decide for him/her-self how much noise is acceptable to achieve efficient cooling. Having the right fans for the job is essential. If you are not satisfied with the noise of your radiator fans, then change them to something better...fans that will keep your CPU cool with a minimum of noise. At the moment, I think the Noctua NF A12x25 PWM is the best choice. They achieve excellent cooling, while keeping quiet doing so. Max speed is 2000rpm, with included Low Noise adapter mounted the rpm is capped at 1700 and even less noisy. They are a new generation of fans, not pretty but who cares as long as they deliver ? If I were you, I'd get 2 of those and get rid of the original rad fans or use those somewhere else in the case.
Age old argument. Sure, using radiator as intake lowers the temps on component/s it's cooler .. but it increase air temp that is going to everything it's heated air is coolng.I think I'd disagree with the early posts here, for an AIO the idea is the get the air over the radiator as cool as possible so normally I'd blow cooler air from outside into the case. Blowing air our over the radiator will warm the radiator!. Just make sure you have enough air flow to keep the GPU cool.
Andi.
No doubt about thatWhile I agree there is a correlation between cooling ability and noise, that is only one part of it.
These CLC radiators are the cheapest, lowest quality, worst efficiency made .. and it doesn't matter what fans are on them, they are not going to cool as well or as quietly as better quality/more efficient radiators or a good air cooler will.
The better fans would push more air with less noise than what he has now, and still keep the same cooling ability. In fact, with more efficient rad fans he could probably even get it at lower rpm.The reason they have such high speed fans is to move the higher volume of air needed to get them to cool. Changing to better fans might lower noise a little, but these CLC radiators are simply not efficient and will not cool well without lots of airflow and that means noise.
So Rachid Khamlichi can speed £60 for top tier fans like NF-A12x25 PWM to lower the noise a little but not have as much cooling ability ..
No, NF-A12x25 PWM simple does not have near as much airflow or static pressure as his stock CLC fans have.No doubt about that
I'm just saying that this would be easier than to change all his case fans. Those are running quiet, he says....the problem is with the rad fans. So there might even be room for a small increase in case fan speed without an audible increase in noise ?
