Don't call them except to cancel, they'll call you. At least they did with me in the last week of cancellation.Just called to push my cancellation back a couple of weeks and give them a chance at hooking me for another 12/18 months.
Still no interest, best they could do was £42 / month for 100MB and phone, or £35 for 100MB with no phone.
Much disappoint![]()
My VM SH3 fails to save my wifi settings when it’s powered on and off so VM are sending out a replacement.
Are they painless to swap over?
It takes a few minutes but will take an hour to download latest updates before you can use it though!My VM SH3 fails to save my wifi settings when it’s powered on and off so VM are sending out a replacement.
Hi Bremen,
Thanks for that, I haven't read up about computers/network stuff in years so very much out of the loop.
So I can plug a network cable from my virgin super hub 3 (Think it is this one) and just plug that straight into an unmanaged switch 12/16 port one and it should work fine?
Yes. No configuration required.
I haven't really thought about a budget yet as I wasn't sure what I actually needed, if I just need an unmanaged 12/16 port switch I have seen those ranging from £20 - £100+ which I guess depends on different options they all have.
Unmanaged switches all are basically the same from a performance point-of-view. Make sure you get a Gigabit switch and not 10/100.
A 16 port unmanaged Gigabit switch is going to cost ~£60.
A 12 port switch would only give you 11 usable ports as you loose one for the connection to the router.
Thanks for replying![]()
I didn’t.Did any one else NOT get a price increase letter?
I pay £40 for 350 only. Don’t think you’ll get any cheaper than £40 tbh. It is their flagship service.Not just me then. I'm paying £42 for 350 only. I got that price a few months ago so still in contract. Was kind of hoping for a price increase so I could try and get them down under £40. Ah well, can't complain.
I didn’t.
Loogabarooga
