- 11 Aug 2012
- Wales
Do these older DC2's suffer from rust?
Later on you could add a turbo and have a mental car.This suggestion gets me going...the Mrs would despise it though. I'll do some Googling![]()
You would get a well sorted R26 Megane F1 for that money - prices are generally on the rise so you are unlikely to lose money on one.
£6-£6.5k would get you a really good one that should have had a good refresh of most typical wear parts by now.
They are no less reliable than any other hot hatch really. Front suspension (swivel hubs) is usually one to make sure is done, as is the cambelt, dephaser etc.
).Money pitsMazda 3 MPS
The car, a Mazda MX-5 NC 2,0 Sport Roadster Coupé 2007.
Complete Modifications list from stock:
- ECU Remap
- Full Race-exhaust with race-cat and CAI
- Larger coolant radiator with aluminum reservoir
- 245/40 17 track tyres, road legal, on 17x9
- Coilovers with 13/8 Springs
- Aftermarket ARB front, no ARB rear
- 6-Pot at front, OEM at the back, 2 piece discs (oem size), race fluid & pads, cooling
- Carbon fibre drivers seat, no passenger seat
- Aftermarket steering wheel
- Approx 1090kg incl ½tank of fuel and 80kg driver (Yes, driver lost some).
- 5 Speed Gearbox with close ratios gear kit (Originally a 6-speed)
- 4,1 FD without LSD (yes, open diff)
- Light flywheel, OEM clutch
- AC and PS delete
- Cro-moly rollbar, welded
- CF Roof (not retractable anymore)
- Lightened & reinforced front subframe
- Seam-welded rear subframe
- Seamwelded door-openings
- Additional bracing underneath
- Small boot spoiler - Small front lip
This is what an MX5 can do with a few tweaks and someone who knows how to drive it.
There are people spending 10's of thousands monthly to make their supercar extra quick who can't get into the 7's. People buying track ready GT3 RS's and GT2's that will never get close to this time.
Boxster 986 S? Especially seeing how the prices of S2000's are going now.
Isn't that the test driver for Koenigsegg? I am pretty sure he would be fast in anything!
The 986 is getting on a bit now and could start to throw some pretty large bills. Servicing at an indy doesn’t have to break the bank, but parts can be pricey. The 986S is a fantastic car but with this remit a slightly scabby s2000 is better than a slightly scabby 986S.
350Z is a good shout but I couldn’t comment on the running costs.
The MX5 looks better and better every time one of these threads appears. How are the Mk3’s for rust?
