Poll: **** The Official Samsung Galaxy Note 9 Thread ****
Which Version Did You Buy?
  • Ocean Blue 128GB Single Sim
    Votes: 31 27.0%
  • Midnight Black 128GB Single Sim
    Votes: 48 41.7%
  • Lavender Purple 128GB Single Sim
    Votes: 0 0.0%
  • Ocean Blue 512GB Single Sim
    Votes: 2 1.7%
  • Midnight Black 512GB Single Sim
    Votes: 9 7.8%
  • Ocean Blue 128GB Dual Sim
    Votes: 7 6.1%
  • Midnight Black 128GB Dual Sim
    Votes: 9 7.8%
  • Lavender Purple 128GB Dual Sim
    Votes: 0 0.0%
  • Ocean Blue 512GB Dual Sim
    Votes: 5 4.3%
  • Midnight Black 512GB Dual Sim
    Votes: 4 3.5%
  • Total voters
    115
28 Apr 2011
Barnet, London
Hmm, so actually I found the option in Advanced Features -> Accessories -> Fast wireless charging... and it's on
So, it turns out my first fast wireless charger really is a fast wireless charger, but only if I use the official wall plug. I have a high Watt multi USB port thingy, which fast charges just about everything, but not this. That's annoying, another plug now used.
The second 'fast' wireless charger, wont fast charge no matter which wall plug I use.
Don
9 Jun 2004
I've not used a wireless charger for a while and I have noticed that the official fast wireless charger is taking a lot longer to charge than the wired fast charger I had with my Note 8. I wasn't sure if that was down to the larger battery or whether wirless chargers just don't charge as quick.
18 Oct 2002
Niptons Ridge
I guess on iOS it wont let you back them up to Google Drive? Now you're on a good OS ( ;) ) you don't need to worry. Have it set to backup each night, when you change phones to another Android you can just press restore.
Generally you don't. Can I ask why you did on iOS? I assume to save battery? Android manages it all for you now and it can actually cause more drain if you kill them all the time. A lot of them will need to be open, or you open them and it takes more to open them from fully closed. If you must, press the app switching button (by default the left one) at the bottom it says 'Close all'. Hit that. As I say, I would try and get out of the habbit tbh.
The other route, go to settings, Device Maintenance -> Battery and hit 'SAVE POWER'. If you know something need to run in the background, you can set it in 'Unmonitored apps' on that same page.
Ok cheers. As you say, I used to close them down to stop them using my battery on my Iphone 7.
If android does the ob for me, then I'm more than happy to let it.
Caporegime
18 Oct 2002
London
I definitely have settled into this phone, it really is the best incremental update I have had so far. Everything just feels a little more polished and refined compared to my Note 8. I am still unsure about the battery though, it has the lasting power - but as I said before, the SoT seems a little hit and miss.
24 Oct 2002
UK
CPW paid the online trade in for my S8+ today. No confirmation via email or text, just appeared! Got the extra £200 though so can't grumble.
Caporegime
18 Oct 2002
London
Any TG screen protector recommendations. Will likely end up with the ridiculously expensive Whitestone DIY UV but would like to see decent alternatives before buying.
Edit - wow the reviews on Amazon don't bode well.
OP
31 May 2005
Did you see AndyCr15's review of a screen protector few pages back ? cheaper than whitestone
27 Nov 2005
Guernsey
13 Aug 2008
Expensive as the Whitestone is its the only one that allows a perfect install because of the jig.
Tips.
Make sure that your surface is completely level.
Make sure you use the dust removal stickers.
When using the tilt on the jig to move the adhesive into position let the adhesive hit the underside of the glass before releasing the glass tab.
Cure the adhesive initially whilst the phone is still in the jig don't remove the lid of the jig before curing.
L33
L33
Permabanned
1 Apr 2003
Unpopular opinion but I think all of these tempered glass protectors are an eyesore. They leave a noticeable and unsightly ridge all around the device and either have that awkward looking cutout at the top, or a black strip with clear masks for camera & sensors which stands out like a sore thumb. They're also completely lacking the anti-reflection and oleophobic coatings so they just look shiny, reflective and tacky like one of the cheap untreated chinese replicas.
I can understand why people use them I'm just surprised there isn't a better solution.
28 Apr 2011
Barnet, London
I'm not sure you do if you think people put them on as they look good?! :p
I managed to slightly pull mine off yesterday and so have decided to completely remove it. I almost always do this though, have it on for about a week then change my mind.... :)
31 Dec 2006
Cardiff
Quick question. I'm debating on getting the note 9 from CPW, if I put in my S8+ I will get £440 back as part-ex. I see they are offering an extra £100 if you take a pay monthly sim at the same time. So has anyone taken the PX offer and taken out the pay monthly sim and then cancelled the sim pay monthly, if so do you still keep the extra £100.
Thanks
Don
9 Jun 2004
Thanks
I purchased mine on a one month rolling deal when they were offering an extra £200 for trade-ins. Phone vodafone and cancelled the plan (still had to pay the £15.50 for one month) before I'd even received my handset and had no problems at all.
31 Dec 2006
Cardiff
Thanks, I don't mind if I've got to pay one month to save a couple of hundred quid. I'm off all week so I may pop in and have a chat with them. It seems a bonkers offer but anyone would be daft to say no to it. From memory Samsung are only offering about half of what CPW are offering.
