Firstly I contacted OCUK this morning and have been advised to speak to Inno3D directly. I have tried on multiple times only to get the same response each time from Inno3D as below.
I was off work last week so despite getting the card back in the post on Friday, I have only today actually opened the box.
I received 3 bags of Haribo what was nice as always! Thanks OCUK but... whoever looked at my card and packaged it back up did not do so correctly (see pictures below). My card on inspection today, is more damaged then when I sent it originally to OCUK.
It seems like the card was damaged by DPD (who I returned via the paid for service by OCUK). I do not believe OCUK would have damaged the card further while inspecting it - why would they? The reason I believe it was DPD is that the card seems to of been damaged more between me sending pictures for the RMA process to start and the pictures OCUK sent to Inno3D
Is this now for OCUK to make a claim against DPD - if they used a service with insurance etc?
When I sent the card, it was in the original box and more than enough bubble wrap and packaging.
Pictures sent to OCUK to start RMA process. - Although cracked and coming away the plastic was still fully attached.
https://i.imgur.com/tYIXCTq.jpg
https://i.imgur.com/NDa8hFY.jpg
https://i.imgur.com/Tunedaj.jpg
The pictures OCUK sent to Inno3D the card shroud etc is now totally disconnected - https://imgur.com/a/BRt7Xvy
The card received back from OCUK as always was well packaged - bubble wrap and air bags, but upon opening the box I was welcomed to my card like this. The card could have been further damaged by OCUK when packaging or in transit by DPD and has at some point had pressure applied to the PCI connector as evident by the depression in the foam.
https://i.imgur.com/8ZoHAWQ.jpg
https://i.imgur.com/zkbmbiH.jpg
https://i.imgur.com/36PNyVj.jpg
https://i.imgur.com/ygqH0DO.jpg
Dear Sir
Firstly, thank you for your kind support of our product,
If your graphics card have any problem,
You can return graphics card and invoice warranty document,
To your local reseller or etailer,
They will provide RMA Service to you.
For your information:
INNO3D Graphics card: 1 or 2 year warranty, ( Different regions are different, please contact the local purchase of stores, )
iChill Graphics card: 3 year warranty ( Artificially damaged, burned parts, oxidation parts, are not included in the warranty, )
The warranty period is decided by the local distributor.
Hope the above information is useful for you.
Best Regards,
Inno3D Support
Best Regards,
Inno3D Support
) and its not covered under warranty, or the card had damaged itself - and the physical damage is not under warranty.
