- 7 May 2016
Thanks mate, I will order the 80. Can't believe they would make a mistake like this. Shame Overclockers don't have them, at least I know I can rely on Ocuk.
You'll have to game like a commoner for the time being
One card wonder hehe
That or set other for an expensive physics-X card hehe
Don't worry though, you'll be sorted soon enough![]()
Hehe I do have them on SLI with a single sli cable. I don't know where to buy one from now, this has really made buying hard.
*cut*
But why 2? 1 is more than enough.
*cut*
. First rule of pcmasterrace: "No such thing as overkill".
Personally if i could get my hands on a cheap, and i mean dirt cheap cause im broke atm, 1080ti i would sli them up, even if my 4790k would choke. Enthusiast for life man
find 1 more old sli cable and use it so you run 2.. im sure there is one in an old motherboard box. Works wonders but looks ugly af.Hehe I do have them on SLI with a single sli cable. I don't know where to buy one from now, this has really made buying hard.
So turns out I was right thinking that the place I bought it from don't even stock these. They had it mixed up on the listing and it should have said pre order which now it does. I said to a friend last night that I thought this was what they had done. Looking online it seems the only place I can get one is by ordering outside the united kingdon, what a pain. They have fixed the website but still have them incorrectly listed on both amazon and fleabay, I have just told them. No one in the uk is stocking these, damn.
OK i have found the correct one, but its located in israel, this may have to do. I have messaged the seller to confirm this is the one pictured but that is defo it.
Am I allowed to post ebay links? Its not really a competitor is it as ocuk don't sell these yet.
Edit - He just confirmed this is the right one. I can't believe I have to order from Israel!
remove the link
but that is the 80mm older style - dont think 80mm really made it into production much im guessing with Turing being known many moons ago
the rainforest have it in stock mind... £20 odd
60mm is A2WAYSLI without the extra L
