Pet hates. People not understanding how traffic light junctions work.
The red light applies to those entering the junction, not those in it. Once you pass the white line you should complete your manouver through the junction unless doing so would cause an accident.
Tonight on the way home I went through a green, but go stopped about 4/5 the way across the junction in the traffic. In the minute or so I was sat the traffic to my right moved off on their green. A 4x4 drives right up to my front wing and when the traffic moved he tried to force his way in. I seen it coming, but I moved forward anyway to see what he would do. He braked, then look up at the traffic lights as much to say, "Yours is red."
"That's not my light anymore mate and you are obliged to yield to traffic already on the carriageway."
But I let him in anyway, but cut the next women who tried the same off.
It's not the first time and it won't be the last. Again, the red light only applies to the white line legally defining the junction. Once past that you should complete your manuever thorugh the junction unless it would cause an accident.
In real world though if you are just over the line, you would wait with the red as it makes sense, but not when you are nearly through the junction. Waiting in the middle of junctions causes far more problems, like the fact I was physically blocking a whole other lane of traffic if I didn't move and the junction would have grid locked up.
EDIT: There is also confusion about repeater lights on the other side of the junction. Often you get lights at the line, but lights on the other side. These are repeater lights, they are for when you are first in the queue and can't see the light now beside you. They have been called into question for causing confusion before, but you are 100% allowed to EXIT a junction under a red. Obviously you need to be careful of pedestrian crossings, but it is perfectly acceptible to approach the crossing, wait on pedestrians and then proceed whether it's red or green.
I think you need to live in the real world.
The traffic is flowing at 40 mph. Do I stop and wait for the car ahead to cover the 70 odd feet, then set off?
Also only the rule about the red is a rule, the remainder is guidance.
agree this is the pragmatic approach ...The traffic is flowing at 40 mph. Do I stop and wait for the car ahead to cover the 70 odd feet, then set off?
so can you explain ... is there no distinction between proceeding across a box junction when you can't leave and this, the non-box scenario ?I know the highway code is only guidance, the clue is in the name, or it would be called the highway law.![]()
I do live in the real world and it's a world where sensible people know the highway code is only guidance, or it would be called the highway law.![]()
You MUST NOT move forward over the white line when the red light is showing. Only go forward when the traffic lights are green if there is room for you to clear the junction safely or you are taking up a position to turn right. If the traffic lights are not working, treat the situation as you would an unmarked junction and proceed with great care.
Every driver must enter an intersection only if his vehicle is not likely to be immobilized
and to prevent the passage of vehicles traveling on other tracks. In particular, a driver
not engage in an intersection of roads in case of report, by the driver of one of the vehicles
That junction is small enough and simple enough there should be no excuse for not reading the traffic well enough to not need to stop in it.
You probably need to drop back a bit from the car in front to improve your visibility if you cannot judge if you will clear that junction or not.
The problem however is typically peer pressure to drive badly in those sorts if situation, driving too close, too fast and going even if the exit isn't clear.
Its survival of the fittest, particularly when its busy, those willing to break most laws (or guidance) will tend to "win"
Less driving, more passenger annoying observation.
Car has climate control, driver has A/C turned off and only turns it on to cool the car down when hot, then turns off again, then on, then off etc.
So - new pet hate - why is the highway code ambiguous in respect of above, it is not surpsiing driving standard is poor
implication is must not go forward on green if junction is not clear.
In comparison I just looked at French law - you get a 135euro/4th level fine Article R415-2
some degree of leniancy with respect to if it was not deliberate and avoidable
Napoleon had it (mostly) right
[edit: yes i know highway code is not the law .. but it should clearly communicate it]
... and then no doubt complains that the car windows fog up.
..R4 programme yesterday about peoples increasing trust in 'AI', if AP had not alreday received enough criticism, which referenceed this storyPlenty of occasions I have had sat navs get me into the wrong lane because someone has changed the lane designations and the sat navs are either out of date or were just wrong to start with.
if you compareThere is a full stop. The "MUST NOT" is law. The rest of the statement is advisory. You can be prosecuted for passing through a red light. You will not be prosecuted for stopping in the middle of a junction, unless you did so deliberately and in a dangerous way.
Box junctions. These have criss-cross yellow lines painted on the road (see ‘Road markings’). You MUST NOT enter the box until your exit road or lane is clear. However, you may enter the box and wait when you want to turn right, and are only stopped from doing so by oncoming traffic, or by other vehicles waiting to turn right. At signalled roundabouts you MUST NOT enter the box unless you can cross over it completely without stopping.
Why!!!?!?! Climate control is one of the best inventions for the car, going back to manual heater controls (even with AC) is a right pain - too cold, turn up the heat a little, ahh now I'm too hot, turn down the air flow, nope too cold now and the windows are steaming up... Climate control - Set at 21 degrees, AC on and forget...Less driving, more passenger annoying observation.
2 lanes entering the roundabout, 2 lanes on and then 2 lanes exiting, lane 1 to lane 2 to lane 1... inevitably when I would have been on their inside*Why!!!?!?! Climate control is one of the best inventions for the car, going back to manual heater controls (even with AC) is a right pain - too cold, turn up the heat a little, ahh now I'm too hot, turn down the air flow, nope too cold now and the windows are steaming up... Climate control - Set at 21 degrees, AC on and forget...
My pet hate, coming from biking is people who straight line roundabouts.2 lanes entering the roundabout, 2 lanes on and then 2 lanes exiting, lane 1 to lane 2 to lane 1... inevitably when I would have been on their inside*
*I don't risk being alongside anything on a roundabout on a motorbike, people just don't bother/are too lazy to look.
https://www.rac.co.uk/drive/news/motoring-news/driver-led-to-cliff-edge-by-sat-nav//
