Interesting because I when I bought my last car went for Ac as opposed to climate.
My last 3 or 4 cars have had climate in them and annoyed me. I never found just set to x gave me what I wanted. I would still get steam ups, mini was a nightmare as it would drop fan speed really low on climate till engine warmed up if cold outside, it did crazy things, like deciding the engine was warm enough and as it was cooler inside then temp i had set would go to 80% fan etc
All of these things make sense. If the engine is cold then the CC cannot produce heat, so why would it want to blow cold air at you? So it will wait until air of the correct temp is available and then turn the fan up high to warm the car (often turning the recirc on), then as the temp starts to come up it will back the fan down. All of these things you would be doing yourself manually. The defog setting is usually a separate manual setting which sets the fan to 90% and up the screen.
Also, not sure about the mini, but in my car (GT86) I can manually override every setting just by modifying it myself.
Unless of course you absolutely want to be at 21 degrees no matter what.
Am I doing 50mph, or 52, or even 54? Who the hell knows!! Arrrrrgh!!
