Hi all, new to this forum so I hope this post is in the right place.
I have a PC with 16GB of ram in it and I'm trying to work out if I can put another 16gb in and what type I need to buy. Here is a screeshot of current specs...
It says I have two slots spare and I think my PC can take 32GB (64-bit Windows 10 can take that, right?) but I have a couple of questions...
A) Do I have to match the existing ram brand/speed etc? I know it has to be DDR3 but I've read something in the past about slots 1/3 having to match and 2/4 having to match. Is this true? In which case, what needs to match?
B) What speed is my current ram? It says 666 but that seems way too low, I swear it was 1666 or 2000 but that number must mean something different. It's a PITA getting the box apart to look so I only want to have to do that once if possible when I buy the RAM.
Is there anything else I need to consider?
 fwiw you can literally stick anything in and it will work. You don't really have to match speed/density as the faster chips will just run at the slower speed. There are some exceptions where things just don't like each other but for the most part you should be ok.
 For example my CPU (TR 1950x) scales very nicely with memory. Just from memory alone you could gain 10% or more between 2133mhz memory and 3200+ memory speeds. That scaling is also relevant for workloads that are not games
