Hi guys,
I was considering getting a PS4, but I'm thinking of buying a PC or laptop for gaming instead. I have little to no knowledge, so apologies if these are basic question or adivce I'm asking for. I have the following requirements:
1. I will probably mostly be playing strategy games like Factorio (requirements here: https://www.factorio.com/buy) and Civ 6 (requirements here: https://www.google.co.uk/search?sou...ab..17.4.4768.0..35i39k1j0i67k1.0.O7NRb7OwoPs) and other similar real-time or turn-based strategy games, as well as games that are available on both console and PC e.g. Assassin's Creed, Hitman, etc. (do these games require greater requirements that strategy or PC games?)
2. I'm not really in need of having the absolute best e.g. willing to sacrifice some quality, e.g. in resolution, if it has a decent impact in terms of lowering cost.
3. The ability to use a PS4 controller would be desirable.
4. Ideally I would like something that will last multiple years and not require regular tinkering to update it.
5. Portability is not really important as I will only play it at home, regardless of whether I get a laptop or PC.
6. I am trying to keep the budget as low as possible, but given my lack of experience and knowledge I'm not really sure what trade-offs to make in terms of price vs technical requirements needed for the points above.
7. I already have a computer monitor (Asus). I also have a very old laptop which I use day-to-day and which is suitable for all my needs (internet browsing, streaming, maybe some Word/Excel now and again etc.). Ideally whatever I buy now would function as a back-up in case my current laptop dies so perhaps ideally whatever I buy would have Windows already installed, although I really stress that my day-to-day needs in terms of computing are basic/not a lot - as long as I can get on the internet and do basic Word and Excel, it will be ok from that point of view.
Given these, would you recommend a laptop or a PC? And for whichever you would recommend, would you recommend a custom built or "off-the-shelf" machine, and how cheaply could I get hold of your recommendation?
Appreciate the help and advice.
J
J
