How good or Bad does Sky HD look on a 65" OLED
27 Nov 2005
Guernsey
Does anyone here own a 4k 65" OLED and have Sky HD ?
As I wondering how good or bad Sky HD looks on a 4k 65" OLED from about 9 feet away..
Thinking I may better going for a 55" instead of the 65"
Am using the older sky hd 1tb box and not the new sky Q box
1 Mar 2010
It would be intereseting to know if there is any difference between sony/lg/pan oled hd->4k upscaling hardware ie. which 65"
sky has the same bitrates and codecs as freeview/freesat(bbc etc) check out the digitalbitrate site, so nothing differentiating about their HD capabilities;
they have not dummed HD down to try and up-sell their 15Mb/s 4k/sdr content.
Caporegime
30 Jul 2013
I have a 65B6 and Sky Q.
Also have the package that gives you 40 HD channels.
I don't really watch standard definition on it to be honest, but the HD channels look good to me.
1 Mar 2010
and tbh i personally think its a waste to have the old sky hd over the sky q silver especially when you can get some good deals to switch over.
just my 2£
but they haven't got that much 4k material other than the films 'they' show & f1/foot
parents switched over, and even though you maybe you can escape the dam £200 install now, they are paying >£50 versus <£30 before.
they can now rationalize this, since they have more space to store stuff, but they could have used catch up before.
OP
27 Nov 2005
Guernsey
Doesn't most tvs now upscale now?
just my 2£
It would cost me over £10 per month more when I priced up to change to sky Q (and if I remember right there was also a install charge to pay)
30 Sep 2003
I've got a 65" oled and sky. Similar viewing distance too. No issues at all with HD and I wouldn't want to go smaller. SD obviously looks crappy.
1 Mar 2010
sky has netflix from november
so will it be hdr ?... apparently no but
On Amazon and Netflix, most UHD content is their own content. Most movies are not in UHD let alone HDR. Sky is showing more movies in UHD then both Amazon and Netflix. Once HDR is available on Sky, it will be even better with more movies with UHD and HDR.
think i had heard that before .
24 Feb 2003
Stourport-On-Severn
Netflix does stream content in HDR, i've watched it when i subscribed. At the time there wasn't much and i doubt there is much more now.
What Netflix did have though was quite a lot of UHD content. If (via Sky Q) that becomes available for £10 including Sky boxsets, then frankly that is a bargain. UHD from Netflix costs £9.99 a month anyway.....................if you already have Sky Boxsets, it's a no brainer.
