- 5 Jun 2018
I don't think a dual slot card will fit in the 3020 sff now that I've been able to look at the mobo.
The case has 2 slot for pcie but the one you would need to use for a 2 slot card appears to be x4 or x1 and not open-eneded.
It is probably possible to get a low profile dual slot 1050 in there, but you would need to modify the case or cut the end of the pcie slot.
Thats what i'm thinking from looking at the images i can find on google anyway.
kind of what i thought but you know the technical words
the only slot is too close to the psu, it leaves room above but not below the card which is where it fouls. which brings me back to thinking about a whole new system again. but i will need to finance it and im not sure if i want to be tied in for 3 or 4 years on something that will be outdated as soon as fortnite runs out of fashion?
My basket at Overclockers UK:
- 1 x AOC E2270SWDN 21.5" 1920x1080 TN Widescreen LED Monitor - Black= £70.99
- 1 x Asus GeForce GTX 1050Ti Phoenix 4096MB GDDR5 PCI-Express Graphics Card= £158.99
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
- 1 x Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30= £119.99
- 1 x Toshiba 1TB P300 7200RPM Performance Hard Drive (HDWD110UZSVA)= £32.99
- 1 x Gigabyte GA-AB350-Gaming 3 AMD B350 (Socket AM4) DDR4 ATX Motherboard= £82.99
- 1 x MARS Gaming Hades MKHA0 Gaming Keyboard - UK Layout= £9.95
- 1 x Corsair Gaming HARPOON RGB Gaming Mouse, Backlit RGB LED, 6000 DPI, Optical (CH-9301011-EU)= £25.99
- 1 x WD Green 3D NAND 120GB 2.5" SATA 6Gbps Solid State Drive (WDS120G2G0A)= £24.95
- 1 x Bitfenix Nova Midi Tower Case - Black Window= £31.99
- 1 x AMD Ryzen 5 Six Core 1600 3.60GHz (Socket AM4) Processor - Retail= £139.99
Total: £780.47 (includes shipping: £14.70)
how future proof would this be? 3 years? 4 years?
