The performance is nearly like for like and should over the long term favour the 2080 + RT + DLSS. If buying new and coming from a GPU where it is WORTH the upgrade I would still be buying a 2080 over the 1080ti.
Anyone with a 1070ti/1080 or 1080ti it is not worth upgrading to the 2000 series.
1070 maybe*
At 4k resolution maybe*
Anything less definitely.
(But not at these crazy prices.)
We are at the end of the day discussing the difference between a 1080ti and 2080. I personally feel it's worth spending the extra £130. But that's just me.
I never said it wasnt like for like, but the 1080ti is significantly cheaper so you get more bang for your buck.
If the 2080 was actually a 2070 and at same price as 1070 launch price, then the tables would be turned, but its not what we have, what we have is pascal at current pricing been a better buy if all you care about is raw performance. The 2080ti has a purpose if a 1080ti is not fast enough but the 2080 I feel is a lame duck right now.
