- 27 Mar 2013
So my shed has a bit of a list, is the best way to level it up, hammer some fencepost's at 45 degrees to straighten then bang some ply across it? If so what thickness ply would work?
Is it literally just the bolts that hold it square (when the roof was repaired, the guy put in thicker bits of wood but I don't think they are screwed down so should be nudgeable).Loosen the bolts, square it up, tighten the bolts?
Yea that's pretty much how it arrived (I didn't assemble it, that was included in the price). I might have a look at it later.Difficult to tell except for you saying the bolts hold it together. Most sheds nowadays are big panels on each side/top/bottom (like big fence panels) that are screwed together at the corners and edges.
