Spec me a budget £500 gaming rig
6 Mar 2013
Hi guys. My brother has tasked me with building him a gaming rig with a budget of £500, which I'm kind of struggling with.
I know it's a bit of a low budget and a difficult challenge but, do as best you can please :p
Already have a mouse, keyboard, monitor and windows... just need the rig.
Thanks in advance!
Ok, guess it's a difficult one...
So I've been racking my brain and I think this is around the best I can do.
Can anyone tell me if it's all compatible or if you'd recommend other parts instead?
My basket at Overclockers UK:
Total: £547.18 (includes shipping: £12.30)
Is the Mobo the correct one for that CPU? :S​
Similar result here tbh. Although I opted for the 1300X rather than the 2200G, as its got better L3 Cache and isnt an APU so you'll get full 16x on the PCI-E for the graphics card.
Total: £513.08 (includes shipping: £13.20)
Actually should have gone for the B450 as you did, its a more up to date chipset and actually a tad cheaper. Both chipsets very similar and will support the Ryzen chips specced above
step up in GPU power and FPS but start to hit the lowest CPU you want to be using really - though lots of room to improve till 2021+ with second hand 2/3/4th gen ryzen chips
rx 570 also comes with 3 free games and think gigabyte still doing £30 steam voucher for the board...
DE
Total: £517.19 (includes shipping: £12.30)
DE
So you don't think a 2nd hand gtx970 for around £100-120 would be a better choice of gpu?
its a solid GPU- just dont get warranty or 3 free games via AMD .
if you could go with the first one i posted, ryzen 5 1400 + gtx 970 but with 550w PSU - be a solid system! and just in budget!
Ah right... they're near identical. Ok there's defo something to think about. He might go for the RX570 along with your first build. Since I think he was getting assassins creed anyway. He might hand over the cash for an upgrade.
