3dMark Night raid benchmark...
Runs and looks a lot better with the resolution set to 8k.
You don't need an 8k monitor to do the above.
Resolution set to 8k.
Single 2016 Pascal Titan stock.
https://www.3dmark.com/nr/4907
4 x 2016 Pascal Titans stock.
https://www.3dmark.com/nr/4932
4 x 2016 Pascal Titans OC.
https://www.3dmark.com/nr/4963
Hey, they finally put up the hall of fame.. I'm currently #7 for 2xgpu and #18 overall... won't last long, but woo, I'm in the top 10! Could only happen on day 1 of a new benchmark :)
Results are all over the place though, there's a guy above me with 2x1080s, and there's folks running single 1080ti's that are beating sli 1080ti systems! This really wasnt intended for gaming rigs!
Ryzen 3 laptop with 2200u.
https://www.3dmark.com/nr/5074
3758
gpu score 4174
cpu score 2076
I think it might do better if I had 8Gb Ram instead of 4. Looks pretty good on a 14" display as it is though.
If anyone is interested I got a cheap 4Gb stick of memory for the laptop to run dual channel. New score.
4429
gpu score 5410
cpu score 2186
The GPU score went up quite a lot.
If anyone owns a 2200G, 2400G or any laptop variant make sure it has dual channel RAM. It makes a huge difference.
Bored this evening so faffing with a Ryzen 2200G
https://www.3dmark.com/3dm/29553705
All default settings as I only have the free version installed
3DMark Score 12833
Graphics Score 17182
CPU Score 5272
Graphics Test 1 71.92 fps
Graphics Test 2 96.68 fps
Night Raid Cpu 109.1 ms
That puts this little system at the number one position for a 2200G as far as I can tell, unless I am reading it wrong. Still got some headroom in the CPU OC, only on the box cooler and don't want to really push to many volts through it. :)
