Case suggestions for dual radiator setup
26 Sep 2018
London
As much as I love the ThermalTake Core P90 its really not a practical case with limited radiator mounting space, currently had to 3D print some mounts to get a second reservoir in there. Also no sound insulation for the fans :( . For show its amazing though!
Therefore I'm looking for some suggestions for a good closed case that will fit a 360mm Alphacool Monsta (80mm thick) in push-pull configuration and a 240mm Alphacool Nexxxos ST30 in either push or pull. Currently using the 270ml XPSC Photon X4 reservoir but would possibly like the option to add a second reservoir when I inevitably crack and purchase a second gpu and split the loop in two (always wanted to run a dual color loop). Tempered glass is a must as is a PSU shroud.
After waaay too many hours trying to find a suitable case I just gave up and decided to demote the Monsta to test bench and get a 45mm thick 420mm radiator, some Noctua AF14 fans and a Phanteks Evolv X case.
An excellent case. I’m sure that will cool very, very nicely.
