Why doesn't my windows 10 show my overclock speed of 4.9?
17 Dec 2004
The "4.00GHz" at the end should be the actual clock speed. So it should read "Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz 4.90 GHz"
win7 and win10 showed my overclocked speed for my i5 2500k and i7 2600k, but they reported 100mhz lower then the actual speed.
Strange, to be fair, my Ryzen shows the overclock speed, maybe its just an Intel thing and how it reports to Windows, what does task manager say ?
Its just odd that every other cpu I have had said my overclock speed in the windows info part,(even in the amd64 days) but windows only reports the base speed with this cpu.
Have you actually overclocked the base CPU speed or have you just increased the maximum which it will boost to?
Given you're CPU is reducing down to 0.8GHz in your screenshot I would guess you've increased the maximum it will boost to under load which is why you would see the correct speed in CPUz or the Task Manager but the stock speed in the CPU description.
That's how my i5 has always displayed.
I have increased the base cpu but I have speed stepping enabled and all of those things, so when the cpu isn't doing much it clocks right down. Thats how I had my 2500k/2600k setup aswel, and windows showed the oc speeds, maybe a tad wrong by 100mhz, but still showed that they were overclocked.
