I was playing WoW and my PC just shut down completely (no warnings, no BSoD, no restart).
Turning the power back on didn't turn the PC on, neither the motherboard switch.
I then turned the PSU switch off, wait 10 seconds to make sure the motherboard's lights are off before I turn the PSU on, and then turn the PC back on via the motherboard switch. It worked.
This has happened 3 times now while I've been playing WoW so I'm convinced there is something rotten in my PC.
I ran a few CPU burn tests (Prime and IntelBurnTest), temperatures went up to 74°C maximum with no shut downs. Waited for a while and played WoW and again, after 7-8 minutes of playing WoW the PC shuts down again. CPU temperature at the time of shut down read 43°C so I'm pretty sure this is not a CPU temperature/fan/heatsink problem.
Any ideas?
Thanks in advance!
Specs:
CPU: Intel 4th Generation Core i7 (4770K) running at stock settings
CPU cooler: CORSAIR Water Cooling Hydro Series H100i CPU COOLER
PSU: Antec HCG 900-GB HIGH CURRENT GAMER - 900WATTS PSU 80 PLUS BRONZE
Rig is 5 years old, arguable haven't re-applied thermal paste since I've owned this PC but then again if you read above it doesn't seem like a heat problem per se.
Any ideas?
Thanks in advance!
Specs:
