Windows 10 32bit on new system
10 Apr 2015
Hungerford, UK, Earth
I know the above may seem bizarre, but I want to know do new CPU/Motherboards support windows 10 32 bit. I realise It will be limited to 4gb ram.
my dad uses AutoCAD 2009 (which I know works on 10 32bit) and some bolt on software that will not work on any 64bit OS and is now obsolete. So hes currently on windows 7 32bit.. hes using office 365 and this is due to stop supporting windows 7 in 2020. So he might just hold out until then. but even with 4gb ram. a new windows 10 with an SSD would be pretty rapid. I would either just upgrade existing with a new SSD so I can revert back to his old build if needed or, thinking of either of the below. would still buy an 8gb kit regardless.
Note: existing PC is i5 650, which I think still would be fast enough
My basket at Overclockers UK:
Total: £277.88 (includes shipping: £9.90)
You could just make the current system into a 32-bit VHD/VM and run that on a brand new very fast 64-bit host OS system.
true... but this seems a bit clunky, using a VM in software you use 100% of the time.. telling to start his PC then Start another virtual one?
It's pretty standard. That's what most servers are doing now. Separate services in individual VMs.
Having multiple CPU cores helps. You can dedicate a portion of your CPU to the virtual machine. If the current one your dad's using is old, it will still be more powerful than that.
Dont run cad on a 32bit system...
The gpu memory has to be copied into system ram and cad uses gpu heavily...so u are going to run into huge performance issues
As far as i know.... ryzen is only supported on 64bit versions of windows??? I can be wrong..but ye tell your dad to think about switching to x64
So ye if your gpu is 2gb.. it should reserve 2gb of ram and u are left with 2gb for windows if u got 4gb ram....
On windows xp? Thats fine.. but windowz 7+... noope
VM is the best solution, I wouldn’t do anything else in your situation.
It leaves a perfectly good system for every other task, and a specialised solution for the one program / workload that requires it.
