Corsair HD RGB LED Cooling fan help please.
1 Aug 2010
Hi all. I've recently upgraded all my fans in the system to Corsair HD120/140 fans.
After rebooting my system and wiping everything nothing seems to be working properly. The fans work properly but the LEDs do not.
I've tried three different Corsair hubs with the same result. Nothing on the settings controller work either. This happens on all 8 fans that I have. Can anyone help me please?
There might be firmware update to the controller within the software. As I read recently there was new version released. Worth a try also to check older Link software
make sure you have the brightness setting turned up in the iCue software, it's settings>lighting node pro> brightness in my case with the slider all the way to the right, should be pretty similar in yours.
are you using the commander PRO? I had a similar issue to yours and it turns out the commander pro failed - wasn't even detected in windows.
