Thanks , looks a bit old to me would have thought a newer model would have been better specced?
What kind of spec did you imagine, and what is your budget?
Thanks, that was around the right budget, I wasn't picking it apart I just though tech might have moved on in 2 years?
From the reading I have done I only need a 1080p @ 60hz as it's for Xbox one s.
This was on my research list ;
iiyama G2530HSU-B1 24.5" G-Master HD LED Gaming Monitor with FreeSync and USB - Black
Unless you simply don't have the space.That's definitely a worse monitor. It's TN for a start, vs VA on the Samsung which will be more vibrant and superior contrast and blacks. It's also 2.5" smaller... that's never a good thingUnless you simply don't have the space.
BenQ EW2775ZH or EW277HDR?
Thanks for the comments thing I'll go for the Sammy just which one.
I am sitting as you would at a work desk maybe a little further away.
Of the two I'd go with the newer one. You're definitely not going to be using this for PC at all? I would just suggest if so then you could get 1440p for this price.
What makes a curved monitor better?Samsung C27F390
Curved monitors are brilliant, and Samsung are probably the best.
