Where Can I get that? Looks like an awesome deal... Can't find it for 291!!
Have a look at google, somewere around the trees of a rainforest
Literally everything there is 400+ boss for CL14 3200mhz RAM.Have a look at google, somewere around the trees of a rainforest
Im using 2666mhz memory with my 8086k and cpu appears to be running fine, as Im getting 1600 in cinebench and thats with cpu at 4.9ghz. If you look at the intel website, it says 2666mhz memory for the 8086k
Only C16.. for 300+...
Search for one of those
F4-3200C14D-32GFX
F4-3200C14D-32GTZ
F4-3200C14D-32GTZKO
F4-3200C14D-32GTZKW
F4-3200C14D-32GTZKY
F4-3200C14D-32GTZR
F4-3200C14D-32GTZSK
F4-3200C14D-32GTZSW
F4-3200C14D-32GVK
F4-3200C14D-32GVR
F4-3200C14D-32GFX ... 16GB £220
F4-3200C14D-32GTZ ... £450
F4-3200C14D-32GTZKO.. unavailable
F4-3200C14D-32GTZKW.. £490
F4-3200C14D-32GTZKY.. unavailable
F4-3200C14D-32GTZR £500
F4-3200C14D-32GTZSK £465
F4-3200C14D-32GTZSW unavailable
F4-3200C14D-32GVK unavailable
F4-3200C14D-32GVR £480
The best I can find for under £300 is C16 3200mhz or C15 3000mhz, which is making me think if I should return my £180 Trident 16GB 3200mhz CL14 for those.
Why you don't keep your current RAM? And if you truly need 32GB then switch.
Many have said that 16GB is good enough for 4K editing.
