Thanks yeah The card is perfect, was tempted to use liquid metal on the GPU but not sure if this is worth the risk?
I fitted mine with liquid metal which on an air cooler will get you to around 70ish c vs 75c.
The gaming x already has good paste on it from factory.
Not really worth the risk unless doing liquid cooling as you get very similar temp losses.
Plus you have to remove and refit the warranty sticker, which is quite easy but still run the risk of killing the card or damaging the sticker.
