Man of Honour
- 20 Dec 2004
- Tamworth
Did my amp overheat because of a lack of ventilation or am I asking too much of it to drive my system?
Here's what happened and my set up.
I was watching a blu ray movie today, at a decent volume, about two thirds of the way through my amp switched off and the standby light was flashing. The top of the amp was very hot to the touch so I assume it's overheated and tripped out.
The amp isn't enclosed at all except for a glass shelf about 40mm above it. TV unit is an Off The Wall Origin S3 and the amp sits on bottom of the unit.
https://off-the-wall.tv/products/origin/
I have a Denon X2300 AV receiver. Probably a couple of years old and it's never tripped out before.
It's running a 5.1.2 speaker set up comprising of Q Acoustics 2050i fronts, 3090 centre and two pairs of 7000 as rears and heights. With a BK Gemini II subwoofer.
Crossovers are set to 60hz front, 90Hz centre, 110Hz rears and 200Hz height
Speakers are rated as follows.
Floorstanding fronts: Frequency Response (+/- 3 dB), Recommended Power: 25-150w, 6ohm Nominal Impedance, 4ohm Minimum Impedance, 92dB Sensitivity
Centre speaker: Frequency Response (+/- 3 dB): 75Hz - 22kHz, Nominal Impedance: 6ohm, Sensitivity: 89dB, Recommended Power: 25 - 100w
Rear and height: Frequency Response (+/- 3 dB): 95Hz-20kHz , Nominal Impedance: 6ohm, Sensitivity: 85dB, Recommended Power: 25 - 100w
