Which BT xbox pad for Windows.. Confusing
12 Apr 2007
Yup both are the same pad and have Bluetooth and powered via a pair of AA batteries. For whatever reason the cheaper model comes with a cable you can use also.
Ok, I figured that was the case, just seemed a bit strange.
Does the cable charge the batteries up or is it simply to power the pad if the battery is flat..
Thanks again.
