EDIT - this is a snug. Regular TV etc is in the main living room.
Question is, spend £4K on an 85" Sony Bravia KD85XF8596BU TV or extend the budget to £5.2K for a Sony VPL-VW260ES 4K 3D projector (don't care about the 3D bit, but the reviews look good).
I'm no CAD/Sketchup expert but the dimensions are to scale.
As you can see from the attached, the 85" takes up some serious real estate on the wall so I'm wondering if the projector's actually worth it. Plus the advantages a TV offers - easier set up and the ability to watch normal TV without near or full darkness. Plus less noise. And cheaper.
The wall on which the TV is mounted is 3100 mm wide and 2446 mm tall (that excludes the cupboard).
The full length of the room is 3600 mm.
It shows an 85" TV mounted on the wall (dimensions exactly match the Sony Bravia KD85XF8596BU).
The front of the sofa is 2000 mm from the TV.
The space to the left is a cupboard which can be knocked out but would like to store AV kit behind glass.
Decision time is now. We're mid build and if going for a projector we need to cut a hole in the ceiling for the projector and trail cables to the AV kit before the flooring upstairs goes down. Same for the TV on the back wall if we choose that option.
Interested in opinions. All I keep reading is once you've experienced a projector you'll never go back, but then some online reviews say large TVs a better by miles. So advice from owners of both welcome.
As it's a snug I can make it about the experience and don't want to end up kicking myself having not invested in a projector. I suppose the question is (and not understanding throw distances etc), will a projector fill more of that back wall? I was going to get some floor standing speakers which would have reduced potential wall area for projecting onto, but now mounting all corner speakers up near the ceiling. So there's an extra 500 mm of wall either side of that TV. Hmmm.
As it is a snug and you already have a normal tv, projector all the way! Are you planning on going Atmos?
