- 25 Feb 2007
- Bedfordshire
Nice, how do you find it? Any complaints or criticisms? How do I get one?
For me it has been the perfect, every day, 3 handed watch. I've had mine about 3 months now so I've had quite a bit of time with it and it really has been a pleasure to wear. Firstly, it is very comfortable on the wrist. Due to my small wrist circumference (16 ¼ cm) many modern watches don't fit me too well. The BB58 being 39mm in diameter and 47mm lug to lug fits me fine so I suspect it will for you too. Secondly, its fairly light but not light enough to feel cheap. You know its there but it doesn't get in the way. It's also fairly thin for a dive watch at 11.5mm so it'll slip under a cuff easily.
Complaints and criticisms...I can't think anything of anything major. The one thing I would probably change is to get rid of the 3rd line of text on the dial, but that is only a minor detail.
I guess if you want one you'll have to put your name down at an AD and wait or pay the premium on Chrono24 for a second hand one. You may be able to ring round some of the AD's in your area to see if they have any in stock but I get the feeling stock is quite limited at the moment.
Here's a video of it on my wrist so you can see how it fits, it shows how it sits better than a couple of photos.
