Apple said they were still using SODIMM on the Mac Mini so base RAM and upgrading it yourself seems cheapest option?£1,448.40 edu pricing for this mac mini.
Hardware
- 3.2GHz 6‑core 8th‑generation Intel Core i7 (Turbo Boost up to 4.6GHz)
- 16GB 2666MHz DDR4
- 512GB SSD storage
Think I'm going to sit tight for an iMac refresh. Really want the 5k retina in my life.
Yeah it's ~ half the priceApple said they were still using SODIMM on the Mac Mini so base RAM and upgrading it yourself seems cheapest option?
But even then the difference in size and weight isn't massive.
They need to drop the Macbook price to sub £1000, at least then their lineup makes some sense.
Macbook for lightweight, basic tasks (which you could argue the iPad Pro does better)
Macbook Air for the student/semi-professional
Macbook Pro for the higher end as before
They could remove the Macbook completely now that the iPad Pro uses USB-C with display out. That combined with their keyboard and mouse would be a quality setup. Totally mobile but turns into a 'desktop' at home.
Was hoping for new CPUs in the iMac at least. In desperate need for a new system and fancied the move from windows.
Might as well sell all your apple products thenI agree with you the prices are getting steep.
Not worth it, it's finally overpriced.
My £650 mini itx build runs rings around a mini.
Yesss I know ur gonna say but it's apple etc apple tax, osx etc. Yeh I know I'm fully invested in the eco system.
But it's now reached the 'not worth it' point.
Can you upgrade the ram yourself? I haven't been able to find anything that confirms this yet.
Do we know if the storage is upgradable or is that a soldered item you need to spec at purchase?
RAM yes - check the product page on apple.com, you can see the SODIMM slots.
SSD no, soldered to the main board.
Do you guys bother with that Apple care. its like another £100+ ?
Do you have kids? Sweaty hands? or a bad temper?
