Hi
I have an old GTX 670 that I want to use again but this card has always had a noisy fan and I finally want to fix it. I know these were noisy cards but I always suspected that it was the bearing that caused the noise so figured I might as well try oiling it. If it doesn't work I've seen a replacement fan that I can order from China anyway, will just take a few weeks to get here.
So I've taken it all apart to give it a clean, pulled back the sticker and it looks like this:
Can I just add a drop of oil straight in or do I need to pull something out? I was expecting some sort of rubber bung and that metal clip on top has thrown me off a bit.
Thanks
Thanks
