I’m trying to replace some damaged video files to my openelec htpc in the living room from my bedroom pc. It starts of at 11mb then it will just drop to zero forever.
You tube works fine and I’m getting 65mbps on Speedtest,
The htpc is connected to a virgin hub 3 which is connected to a WiFi router upstairs to my pc all connected by Ethernet. Hub to upstairs router and router to pc Ethernet is a diy job totaling 60m. (I have used the whole 60m reel to connect the hub to the pc before with no issues @11mbs)
I have googled this and unchecked remote differential compression api support.
I have used power plugs from the hub 3 to pc and the same 11mbs then zero (bypassed Ethernet cable from downstairs hub 3 to upstairs router)
I have moved the upstairs power plug closer to pc with different Ethernet cable and now I’m getting 8mbs then zero.
I have notice that it randomly starts at kbs then stops.
I’m going to leave it running overnight and see what happens.
Then I haven’t a clue, so what do I check/ do next?
I’m transferring using Windows explorer by typing the htpc’s IP address
