Brown sand/sludge in loop
23 Oct 2006
Hello
Can anybody help diagnose this brown sludge/sand looking substance I found when dismantling my loop?
I have been running Mayhems H20 along with various EK/XSPC and Alphacool products/fittings. I have an EK, Mayhems and Black Ice radiator.
Since my clear tubing is also now tinted brown, I assume this substance is the cause?
If it helps I ran the Mayhems cleaning kit through my loop before this sludge started to appear, so I was surprised to see it materialism. Is one of my radiators falling apart or is this what corrosion looks like?
FgO0gAM
https://imgur.com/a/FgO0gAM
FgO0gAM
Thanks
Hello
file:///D:/Downloads%202/IMG_20181105_194658.jpg
your image isn't showing anything. upload it to an image hosting site like imgur and post the BB code link
https://imgur.com/
p.s. brown sandy sludge does sound like oxidation of some sort
I added the Mayhems biocide when I initially put the loop together and then again after a few months. The brown staining happened fairly quickly as the loop hasn't been in use all that long.
Best case: Algae, Plasticizer.
Worst case: Corrosion.
Mayhems H2O is basically just high quality water, you have to add things like corrosion inhibitor and biocide (or use it to dilute concentrated coolant).
I used Mayhems Biocide in accordance with the instructions provided, i.e. once every 2-3 months if I remember correctly.
I was just surprised by the rate at which everything turned brown. I should have mentioned that the EK monoblock I had in my loop also had some strange brown staining despite being new. When I contacted EK they told me that it was just some manufacturing residue/oil and 'wouldn't affect performance'.
It definitely seems to have affected the aesthetics though. I couldn't stand looking at a loop which looked like it was circulating fresh urine so I dismantled the whole thing. I'd rather not have to do the same thing again, so am just weighing up changing all the main components versus giving them a clean.
Thats flux, you need to strip and clean . Get the mayhems blitz cleaning kit and part 1 the rads , strip and clean all your blocks and part 2 the whole system.
