New PC boots to windows green screen, only on HDMI gtx780
1 Sep 2010
Bristol, South West
Hey guys.
Picked up a used system recently but having issues getting into windows, with HDMI...
Everything is normal up until after entering windows - Circular windows 'loading' symbol after win10 logo, then BAM... Green screen, but only does this over HDMI out on the gtx780.
-System still seems responsive, I can move the mouse cursor.
-Alt+ctl+del does not bring up task manager.
-The cursor can disappear off the right side of the screen, and the bottom.
-When moving to the bottom, the cursor changes to an "I" with like a box around it.
-Over HDMI, it does boot to windows at 4k (native) resolution.
-Drivers have been updated to latest.
Quite annoying, as I want this over HDMI, and do intend to sell the card soon. Is the HDMI out port screwed? How do I determine this?
Specs...
Win10 (64bit)
i7 4770k (stock)
Asus z87-k
EVGA gtx 780
Panasonic tx-50dx750b (4k TV)
It Does NOT do this when...
-Connecting mobo out - TV with hdmi - hdmi
-Connecting gpu - TV with DVI - Hdmi
Any ideas?
Thanks in advance
Have you tried with a different display i.e. different tv or preferably a monitor?
TV can be a bit picky about displaying pc images i have found,timings etc or something
The same display is being used to display an image from my 2500k build, at the same time (4770k is on AV2, 2500k is on AV1)
Tried changing the ports over - Same issue.
Ahh what I was meaning is can you try the pc with the green screen gfx card on a different tv/monitor?
No... Only have the one screen here... Dammit.
Booting in safe mode makes no difference.
I wonder why it only does this on the hmdi out.... It's so out. DVI-out is literally perfect. And I have no idea how, but it even sends sound to my tv, then to my amp. Didn't even know DVI could send audio.
Yeah something is dfinitely wrong with the port in that case, perhaps even card.. DVi should not send out audio
I wish my fury x could do this
Lol im using
Displayport to dvi to hdmi
Basically displayport adaptor to dvi going out my gpu...
Then dvi to hdmi cable
Wow that sounds like a pain... I always feel like a cowboy running one adaptor to another... Yeeeee Haw!!
But yeah I dodnt change any settings for DVI to send audio... Its just fresh w10 install Odd...
