Xenon-look Headlight Bulbs - Do Actually Improve Nightime Visibilty Over Normal Halogen Bulbs?
13 Apr 2013
La France
I’ve recently gone from driving a 2017 Honda CR-V that had rather excellent dipped and main beams to driving something else from 2017 which has regular halogen bulbs for both.
Which wouldn’t be so bad if I hadn’t just moved to a very rural area where you only get white road markings on the larger D roads and cat eyes are only found in actual cats.
Are the various “xenonalike” blue/white headlight builds from Phillips and Osram actually deliver better visibility at night or is it just a marketing trick?
15 Nov 2005
Newcastle
Just remember that the brighter you go the more impact it has on the bulbs expected lifespan. The Philips RacingVision bulbs for example only have a lifespan of up to 200hrs
15 Nov 2005
Newcastle
Better that than missing someone or something on the road!
You've got more chance of missing something/someone when 1 of your bulbs prematurely fails when you're driving at night ;)
I'm not saying don't get better bulbs. I've got Philips XtremeVision in my R26 which are much better than the crap that was previously fitted, and they have am expected lifespan of 400hrs. The 50% reduction in expected run time of the RacingVision wasn't worth it for me for a small amount of extra output. For others this may be different, my point was to highlight the downsides of higher output bulbs that many are unaware of :)
3 Sep 2012
P town
What does life span have to do with when the bulb will fail? In either case you could be driving at night..
15 Nov 2005
Newcastle
Because bulbs with lower lifespans will fail more frequently. In my works van I could hit 200hrs of driving with my lights on around 10 weeks. Again you seem to be missing the point of my original post
OP
13 Apr 2013
La France
Since it’s pitch black by 6pm here, I went with the Xtreme Visions as their 400 hour life span means that they should last me the best part of a year.
Will report back when I’ve got them fitted.
21 Oct 2002
Scotland
Is that the Philips 130% ones? I just had one of them blow after 2 years and 2 months on the car so I'm very impressed with their lifespan.
OP
13 Apr 2013
La France
Yes. Very happy with their performance so far. Not only do the main beams (H7) throw more and clear light further dead ahead, they really pick out the sides of the roads.
Even the dipped beams (H1) provide far better visibility than the OEM bulbs.
The only downside is that the new bulbs make the 5W side/DLR bulbs look more yellow than a chain-smokers fingers.
3 Jun 2012
Why not get some LED headlights?
We fitted some nice ones off Amazon to my wife's car. They actually rival my Xenon's and were £60 for the set. Been running fine for 9months
7 Feb 2004
North East
Which set?
I looked into led a while ago and it didn't seem viable due to light being bright, but short range, getting too hot or questionably using resistors to trick bulb sensors.
Id be interested if the market has moved on :)
OP
13 Apr 2013
La France
Just a little update.
Finally had to replace both my H7 dipped beam Xtreme Vision bulbs yesterday. Weird that they both failed together, but have been utterly impressed with their performance and can’t complain about almost 3 years of use for €45.
12 Jul 2007
Stoke/Norfolk
My, maybe mistaken, understanding is the distance remains pretty similar for the same output power (55w) but that the whiter colour of Xenon's makes it a bit easier at the range limit to see small objects vs the more yellow halogen bulbs at the same range.
22 Nov 2006
Least you can replace them, the LED bulbs in mine are sealed in, have to replace the entire headlight unit if a bulb ever fails (hopefully they'll last long enough!)
Yep that is the problem with the "approved" LED ones. If a DRL LED bulb goes (or starts flickering) it will also fail the MOT for that so you have to replace the whole thing.
Some can cost £1000+ each. Another example of a new over-engineered tech which is worse than the old simpler one.
