Hi all,
getting around to replacing my iMac for lightroom work, hobbyist use with a little photoshop and general pc duties. I've a synology NAS and WHS2011 for storage and media serving.
I'm reusing some odd bits and donations from work, so using a Silverstone HTPC (ATX) case with an OCZ 650W mod power supply and a Radeon Pro WX7100 and a reasonable amount of balanced/quiet fans.
So looking at CPU, MBoard, 16GB Memory and local storage, probably not bothered with overclocking. Keen on something instant on, or near as and stability. It will Drive two 27" AOC monitors at 1920x1080, which i already have. Budget £800'ish, if i can save money but get something useable, then i'm all for that.
CPU, I've lost track of where Intel/AMD are, Lightroom doesn't make use of lots of cores, four possibly, but does like high clock speed. So Intel or AMD?
Motherboard, again depending on CPU, what would you recommend? I like the idea of a boot SSD, something like the samsung evo's 256GB and another fast SSD/Storage of about 1TB for local files. And it looks like after CPU, what boot and storage medium define the m/board.
Also like the idea of everything board mounted, minimum cables, SATA or otherwise.
So, what CPU, bits would people go for.
then they are truly awesome. Always wanted to try a copper IHS over the top of one !
