You need to change the DNS settings to point to OpenDNS.
The local IP address and gateway won't change.
You can also change the DNS settings on your router if it allows it. If your devices have dynamic IPs they'll pick up the revised DNS settings at the same time.
If you want devices to have fixed IPs use the IP reservation features that the router should have.
It's just an experiment for me. I was helping a friend in another country help log their families history. I thought I'd set it up on mine as I'm helping them. This is why I originally asked for help with the Alcatel router.
I have a Plusnet hub one. And there's no DNS changing options on that.
Changing it on all devices is a non starter for them, so I'm hoping they can change dns. I'll find out later.
