- 30 Aug 2018
Tldr: don't do it
Yes. I think Der8auers findings mirror those of gamersnexus.
The 9980XE might be better once delidded.. assuming you don't destroy the thing in the process. We wont know until someone tries using liquid metal successfully.
Tldr: don't do it![]()
lets hope can revive it. Shame to kill a CPU like that,Gamers nexus asked him to. He said himself he wasn't going to but they were curious about how a delid and lm would affect oc potential given the limited headroom at stock.Does make you wonder why he bothered. Other than trying to be first. But that was a fail.
But if it the same silicon as the 7980xe isn’t that already known?He did explain it in the vid though... more to see how the solder and variation in core temps could be improved.
There's an extra + as well i think, same change as the coffee lake refresh.The only difference is it’s soldered so obviously not...
14+++++++++++++++++++++++++++++++++++++?
That’s my point. The only difference is the STIM so once you remove that you effectively end up with a 7980XE, which has already been done and tested. The 9980XE didn’t even get the hardware mitigations for spectre that the Coffee Lake refresh got.The only difference is it’s soldered so obviously not...
It's the same cpu. It's not going to do anything more...... The efficiency is the same also...
