- 15 Feb 2003
- Europe
It seems the mathematicians are out in force on the forum today, so I have a fairly basic question.
Let's say there are two sealed fibreglass cubes. Each empty cube weighs 1kg and has a volume of 1m3
The first cube (a) is filled with air at standard atmospheric pressure at sea level, on a day where the temp is 25c. The second cube (b) is filled with a two part foam with a density of 40kg/m3.
Both boxes are left to float in seawater. The average density of which is 1025kg.
Which box will float higher in the water?
If we then add a 100kg weight on top of the boxes which box will have more of an effect on?
P.S Neither of the boxes are on a treadmill
Edit - changed the box weight otherwise it would it sink. lol
