Help No C6 State on my Ryzen PC's bios??
9 Dec 2017
hey guys,
I'm having some stability issues with my ryzen i litterly tried everything
i read online that disabling c6 state can help with stability and crashes but
my motherboard is a asus prime a320m-k it doesnt allow OC also c6 state is not anywhere in the bios...
only thing i can find is Global C States… is that c6?? if not then idk because c6 is clearly not on my bios..
what to do?
It's an A320 motherboard, they are designed to not have any overclocking features on the bios.
What power supply and cooler are you using with the PC? What sort of stability issues are you having and have you checked temperatures?
my pc crashes randomely during idle mostly, it has done it before in game tho
it usually happens like once every 2 weeks and my event log shows kernal error crash
my psu is antec vp 500watt,ryzen 5 1500x.. also my ram is crucial 8gb ddr4 i thought at first it was that but i checked qvl and its on there..
i tried everything like all my settings on auto, manually settings etc...
im now trying to see if disabling c6 or c states will help cause ive read and heard it caused crashes and they fixed it by disabling it,
should i disable c state?? i guess c6 i cant disable since its not there like you said
also my temps are great..
since i disabled xfr my vcore is 1.2v
and temps idle are in 30s and during game in 40s NEVER 50s
also stock cooler its that wraith spire thing that came with the ryzen
