The above link states if you sit 7 feet or further away from a 55" TV you may as well buy 1080p it wants you to sit 3 feet away from a 55 inch.
So I would use common sense
From that link my 65" isTHX is concerned with immersion really not resolution, IIRC it's between 26-36 degrees.
This does it http://myhometheater.homestead.com/viewingdistancecalculator.html
So 55" is 6ft-9ft, ish. I'd personally go for the lower end of that for movies.
Recommended THX viewing distance is 7.3 feet
And 10.2 feet Maximum THX viewing distance
what
only 8.5 feet for Maximum Viewing Distance for HDTV(Fully resolved 1080i; 1920 x 1080)
But thats for a 1080i resolution, so 4k would be a lot less.
Ok sorry makes sense. ThanksAgain, THX spec immersion not visual acuity. Resolution doesn't matter, what is the correct size/distance to provide an immersive experience?
THX think this is 40 degrees (front row), to 36 degrees (back row).
