- 17 Jun 2012
Is this standard practice now, to have to video the card before an RMA is accepted? Seems a bit daft, the card can just be dropped in a test rig and the problem will be obvious in about 30 seconds.
If it's not in the companies terms and conditions for an RMA that you agreed to when buying the product then I'd tell them to do one.
I can't see anything here that mentions a video, maybe I'm blind.
https://www.overclockers.co.uk/returns
Bailey is the one asking for the video...
Seem you probably have mentioned about a specific issue or a problem that the card is exhibiting, and Bailey probably just asking for a video for the that could show them exactly want it is. May be if you have included your inquiry, or at least explain what the problem is with your card, there would be more context to this situation? I mean if it is an issue that can resolved remotely via technical support and not a hardware fault, then that's no reason for a RMA to be carried out.
You don't have a smartphone?
Surely if you have a half-decent phone, you would be able to record a video of what problem is the card cause on your monitor?
Sorry if I came across the wrong way, and I did not try to imply you are ranting as I understood that you weren't. It's was just a bit difficult to fully understand the situation without the full context.No, I work on building sites and have broken my last two so I just use a cheap crap dumb phone.
There is no problem on the monitor to record, one of the fans has stopped working and makes an odd noise, they don't even need to do any thorough testing to test that, plug it in and fire it up, voila.
Just to be clear I didn't post in hear to moan, I posted to find out if this is a regular thing now with RMAs
Haha.Do you guys not have phones?
Do you not fully read threads?Do you guys not have phones?
