- 30 Aug 2018
I'm wondering if there is anyone here in a position to compare the OC of a 9 series CPU on both an Asus and Gigabyte z390 mobo.
I have read a couple of reviews and user reports that the Asus Maximus range is allowing for 100mhz or so higher clocks with the same or even lower voltages than the gigabyte board on the same CPU.
I understand there is a significant difference in power delivery between the boards.
I'm curious if this is to do with the Bios differences, because if it is I am wondering if a) gigabyte could get an additional 100mhz with a bios update and b) whether future overclocks could potentially be improved by bios updates for all boards?
Edit: I've also read that the z390 Maximus range reports voltage differently than the previous range, ie more accurately, which could explain why it is reporting lower voltages.
