My psu isn’t that old it’s a super flower 1300 watt .Sounds like a PSU issue. Is your PSU single or multirail? Also are you using seperate power cables?
My psu would be multi rail .What about your cables? Are you using seperate cables? People have been having issies using single cables on multirail PSU's
You using separate power cables then yeah?My psu would be multi rail .
i installed 3 sets of driver s today and used ddu to no avail no I’ve posted on there CS forum asking for a rma so have to wait Ona response now not happy at all I’ve had the card since Friday and can’t believe this is happing . Reading on nvidias site many other ppl are having problems with there cards to and they have the micron ram asus and other makers have Samsung and Hynix ram.Im using latest drivers. Well mine only seems ok if nothing is overclocked, so will update tomorrow when my new PSU comes.
I obviously want my CPU clocked to 4.6ghz as it was before and I would like to be able to OC the GPU too, if I fit the new PSU and it crashes then I will have to get in touch with OCUk.
I already sent them a web ticket. I got a reply this morning asking if my BIOS is up to date, and to try a fresh OS install. No suggestion that my current 650w PSU is not up to scratch, like I said my 980ti and CPU under load/gaming was pulling 350-400w. If I knew where the plug in meter was I would try it now, I cant imagine the 2080ti is pulling that much more power though?
I am going to reinstall with DDU now then try a conservative OC eg. just raising power limits.
Thanks,
Sean
I haven’t OC the card never do I’ll keep a eye on it if it persists then it’s going back ...
It’s not working have to do more testing when I get home from work.How's RayTracing?
@SeanC5 wot colour are your lights above the pci express power connectors?
