- 29 Sep 2010
Building a cheap rig which is mainly going to be used for Zwift but the odd bit of gaming too,
The cpu in the build is a non k i5 2500 in a h61 so no change to multipliers so will run completely at stock. (Might upgrade this to i7 2700 but cannot find one FS currently)
What would you recommend in terms of a suitable GPU to run along side this for the best possible performance? Don't want to bottleneck or have more power than required, 500w corsair PSU to power.
Currently have a r9 270 to fit into this once its built but think the cpu could handle more than this? Will be purchasing 2nd hand off the MM rather than new to keep costs as low as poss.
Thanks
Thanks
