ASUS Aura Sync compatible radiator 120mm fans?
18 Oct 2002
As per the title, I am looking for some hi pressure 120mm radiator fans that are compatible with Aura Sync. Can anyone offer suggestions for fans that are compatible and quite? Thanks
Thanks for the reply, but I was hoping for an all in one solution to cut down on the number of cables.
Lots of RGB fans have separate RGB and power/speed cables so this may not end up using more cables. The Halos are a nice solution as you can choose exactly what fan you want, and reuse the Halos later if you replace fans.
There seems to be 2 different versions. Whats the difference between the Lux and the standard Halo?
Lux's frame is made of Aluminium, while standard one is a plastic frame.
For just fan's, EK's very solid Vardar fans which are designed to work on radiators come in RGB flavor: https://www.overclockers.co.uk/ek-w...0er-rgb-500-2200-rpm-fan-120mm-fg-00b-ek.html
Lian Li also do some - pack of 3: https://www.overclockers.co.uk/lian-li-br-lite-rgb-pwm-120mm-fan-triple-pack-silver-fg-00a-ll.html
A number of others on this page to check also: https://www.overclockers.co.uk/air-cooling/fans/rgb-fans?p=3 your looking for the smaller brands as the larger ones, Corsair, NZXT, etc tend to have propitiatory bits connection's for RGB
Actually there are 4 versions: RGB and Digital RGB in standard and Lux versions.
RGB looks to be 4-pin 12V RGB LEDs, Digital looks to be 3-pin 5V addressable LEDs
Normal Halos are plastic, Halos Lux are aluminium.
And everything comes in both 120mm and 140mm sizes too.
